Oggi è il 17/02/2019, 18:03
Rispondi all’argomento  [ 4 messaggi ]
 [Thread Ufficiale] MSI B85M-E45 (Intel)
Autore Messaggio
Amministratore Up.It!
Rispondi citando
Messaggio [Thread Ufficiale] MSI B85M-E45 (Intel)
CPU
• Supports 4th Generation Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1150 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® B85 Express Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 1066/1333/1600 DRAM up to 64GB Max
• Supports Dual channel mode
• Supports non-ECC, un-buffered memory
• Supports Intel® Extreme Memory Profile (XMP)
Slots
• 1 x PCIe 3.0 x16 slot
• 2 x PCIe 2.0 x1 slots
• 1 x PCI slot
On-Board SATA
• SATAIII controller integrated in Intel® B85 chipset
- Up to 6Gb/s transfer speed.
- Supports four SATAIII port (SATA1~4) by B85
• SATAII controller integrated in Intel® B85 chipset
- Up to 3Gb/s transfer speed.
- Supports two SATAII ports (SATA5~6) by B85
Supports Intel® Rapid Start Technology, Intel® Smart Connect Technology*
* Supports Intel Core processors on Windows 7 and Windows 8.
USB
• 4 x USB 3.0 ports (2 ports on the back panel, 2 ports available through the internal USB connectors)
• 8 x USB 2.0 ports (4 ports on the back panel, 4 ports available through the internal USB connectors)
Audio
• Chipset integrated by Realtek® ALC887
- 7.1-Channel High Definition Audio
LAN
• Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Realtek® 8111G
Internal I/O Connectors
- 1 x ATX 24-Pin power connector
- 1 x 4-pin ATX 12V power connector
- 1 x 4-pin CPU fan connector
- 1 x 4-pin system fan connector
- 1 x 3-pin system fan connector
- 4 x SATA 6Gb/s connectors
- 2 x SATA 3Gb/s connectors
- 1 x Clear CMOS jumper
- 2 x USB 2.0 connectors (supports additional 4 USB 2.0 ports)
- 1 x USB 3.0 connectors (supports additional 2 USB 3.0 ports)
- 1 x Serial port connector
- 1 x Parallel port connector
- 1 x TPM Module connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
Back Panel I/O Ports
- 1 x PS/2 keyboard port
- 1 x PS/2 mouse port
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN Jack
- 1 x 3 in 1 audio jack
- 1 x HDMI port, supporting the maximum resolution of 4096x2160@24Hz, 24bpp/ 2560x1600@60Hz, 24bpp/ 1920x1080@60Hz, 36bpp
- 1 x DVI-D port, supporting a maximum resolution of 1920x1200 @60Hz
- 1 x Graphics port, supporting a maximum resolution of 1920x1200 @60Hz
This platform supports dual-display and triple-display function.
BIOS
• The motherboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The motherboard provides a Desktop Management Interface(DMI) function which records your motherboard specifications.
Dimension
• 9.0 in. x 9.6 in. (22.8 cm x 24.4 cm) MIicro-ATX Form Factor
_________________
ImmagineThe Future is Now !
06/02/2014, 13:46
Profilo WWW
Rispondi citando
Messaggio Re: [Thread Ufficiale] MSI B85M-E45 (Intel)
CPU supportate:
Core i7 Haswell i7-4771 100 3.5 1M 8M C0 84 HD Graphics 4600 1200MHz 7817vA0.zip
Core i7 Haswell i7-4770T 100 2.5 1M 6M C0 45 HD Graphics 4600 1200MHz 7817vA0.zip
Core i7 Haswell i7-4770S 100 3.1 1M 6M C0 65 HD Graphics 4600 1200MHz 7817vA0.zip
Core i7 Haswell i7-4770K 100 3.5 1M 8M C0 84 HD Graphics 4600 1250MHz 7817vA0.zip
Core i7 Haswell i7-4770 100 3.4 1M 8M C0 84 HD Graphics 4600 1200MHz 7817vA0.zip
Core i7 Haswell i7-4765T 100 2.0 1M 8M C0 35 HD Graphics 4600 1200MHz 7817vA0.zip
Core i5 Haswell i5-4670T 100 2.3 1M 6M C0 45 HD Graphics 4600 1200MHz 7817vA0.zip
Core i5 Haswell i5-4670S 100 3.1 1M 6M C0 65 HD Graphics 4600 1200MHz 7817vA0.zip
Core i5 Haswell i5-4670K 100 3.4 1M 6M C0 84 HD Graphics 4600 1200MHz 7817vA0.zip
Core i5 Haswell i5-4670 100 3.4 1M 6M C0 84 HD Graphics 4600 1200MHz 7817vA0.zip
Core i5 Haswell i5-4570T 100 2.9 512KB 4M C0 35 HD Graphics 4600 1150MHz 7817vA0.zip
Core i5 Haswell i5-4570S 100 2.9 1M 6M C0 65 HD Graphics 4600 1150MHz 7817vA0.zip
Core i5 Haswell i5-4570 100 3.2 1M 6M C0 84 HD Graphics 4600 1150MHz 7817vA0.zip
Core i5 Haswell i5-4440S 100 2.8 1M 6M C0 65 HD Graphics 4600 1100MHz 7817vA0.zip
Core i5 Haswell i5-4440 100 3.1 1M 6M C0 84 HD Graphics 4600 1100MHz 7817vA0.zip
Core i5 Haswell i5-4430S 100 2.7 1M 6M C0 65 HD Graphics 4600 1100MHz 7817vA0.zip
Core i5 Haswell i5-4430 100 3.0 1M 6M C0 84 HD Graphics 4600 1100MHz 7817vA0.zip
Core i3 Haswell i3-4340 100 3.6 512KB 4M C0 54 HD Graphics 4600 1150MHz 7817vA0.zip
Core i3 Haswell i3-4330T 100 3.0 512KB 4M C0 35 HD Graphics 4600 1150MHz 7817vA0.zip
Core i3 Haswell i3-4330 100 3.5 512KB 4M C0 54 HD Graphics 4600 1150MHz 7817vA0.zip
Core i3 Haswell i3-4130T 100 2.9 512KB 3M C0 35 HD Graphics 4400 1150MHz 7817vA0.zip
Core i3 Haswell i3-4130 100 3.4 512KB 3M C0 54 HD Graphics 4400 1150MHz 7817vA0.zip
Pentium Haswell G3430 100 3.3 512KB 3M C0 53 HD Graphics 1100MHz 7817vA0.zip
Pentium Haswell G3420T 100 2.7 512KB 3M C0 35 HD Graphics 1100MHz 7817vA0.zip
Pentium Haswell G3420 100 3.2 512KB 3M C0 53 HD Graphics 1100MHz 7817vA0.zip
Pentium Haswell G3220T 100 2.6 512KB 3M C0 35 HD Graphics 1100MHz 7817vA0.zip
Pentium Haswell G3220 100 3.0 512KB 3M C0 53 HD Graphics 1100MHz 7817vA0.zip
Celeron Haswell G1830 100 2.8 512KB 2M C0 65 HD Graphics 1050MHz 7817vA0.zip
Celeron Haswell G1820T 100 2.4 512KB 2M C0 35 HD Graphics 1050MHz 7817vA0.zip
Celeron Haswell G1820 100 2.7 512KB 2M C0 65 HD Graphics 1050MHz 7817vA0.zip
Xeon Haswell E3-1285V3 100 3.6 1M 8M C0 84 HD Graphics P4700 1300MHz 7817vA0.zip
Xeon Haswell E3-1280V3 100 3.6 1M 8M C0 80 N/A 7817vA0.zip
Xeon Haswell E3-1275V3 100 3.5 1M 8M C0 84 HD Graphics P4600 1250MHz 7817vA0.zip
Xeon Haswell E3-1265LV3 100 2.5 1M 8M C0 45 HD Graphics 1200MHz 7817vA0.zip
Xeon Haswell E3-1245V3 100 3.4 1M 8M C0 84 HD Graphics P4600 1200MHz 7817vA0.zip
Xeon Haswell E3-1230V3 100 3.3 1M 8M C0 80 N/A 7817vA0.zip
Xeon Haswell E3-1230LV3 100 1.8 1M 8M C0 25 N/A 7817vA0.zip
Xeon Haswell E3-1225V3 100 3.2 1M 8M C0 84 HD Graphics P4600 1200MHz 7817vA0.zip
Xeon Haswell E3-1220V3 100 3.1 1M 8M C0 80 N/A 7817vA0.zip
Xeon Haswell E3-1220LV3 100 1.1 512KB 4M C0 13 N/A 7817vA0.zip
_________________
06/02/2014, 13:47
Profilo WWW
Rispondi citando
Edit 3
_________________
06/02/2014, 13:48
Profilo WWW
Rispondi citando
Thread Open
_________________
06/02/2014, 13:48
Profilo WWW
cron
Designed by STSoftware.
Hosted by MondoWeb
