Oggi è il 19/07/2019, 16:15
Rispondi all’argomento  [ 8 messaggi ]
 [Thread Ufficiale] MSI H87-G43 (Intel)
Autore Messaggio
Amministratore Up.It!
Rispondi citando
Messaggio [Thread Ufficiale] MSI H87-G43 (Intel)
CPU
• 4th Generation Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1150 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® H87 Express Chipset
Main Memory
• Support four DDR3 DIMMs 1066/1333/1600 MHz . up to 64GB Max
- Supports Dual-Channel mode
- Supports non-ECC, un-buffered memory
- Supports Intel® Extreme Memory Profile (XMP)
Slots
• 1 x PCIe 3.0 x16 slot
• 1 x PCIe 2.0 x16 slot
- PCI_E4 supports up to PCIe 2.0 x4 speed
• 2 x PCIe 2.0 x1 slots
• 3 x PCI slots
On-Board SATA
• SATAIII controller integrated in Intel® H87 chipset
- Up to 6Gb/s transfer speed.
- Supports six SATAIII ports (SATA1~6) by H87
- Supports Intel Smart Response Technology, Intel® Rapid Start Technology and Intel® Smart Connect Technology*
* Supports Intel Core processors on Windows 7 and Windows 8.
• RAID
- SATA1~6 support Intel® Rapid Storage Technology enterprise (AHCI/ RAID 0/ 1/ 5/ 10) by Intel® H87
USB
- 4 x USB 3.0 ports (2 ports on the back panel, 2 ports available through the internal USB connectors)
- 10 x USB 2.0 ports (6 ports on the back panel, 4 ports available through the internal USB connectors)
Audio
• Realtek® ALC892 Codec
- 7.1-Channel High Definition Audio
LAN
• 1x Realtek® 8111E Gigabit LAN controller
Internal I/O Connectors
- ATX 24-Pin power connector
- 8-pin ATX 12V power connector
- 2 x 4-pin CPU fan connectors
- 3 x 4-pin system fan connectors
- 1 x Clear CMOS jumper
- 6 x Serial ATAIII connectors
- 2 x USB 2.0 connectors (supports additional 4 USB 2.0 ports)
- 1 x USB 3.0 connector (supports additional 2 USB 3.0 ports)
- 1 x Serial port connector
- 1 x Parallel port connector
- 2 x System panel connectors
- 1 x TPM Module connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
Back Panel I/O Ports
- 1 x PS/2 keyboard/ mouse combo port
- 6 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN Jack
- 1 x 6 in 1 audio jack
- 1 x VGA port, supporting a maximum resolution of 1920x1200 @60Hz, 24bpp
- 1 x DVI-D port, supporting a maximum resolution of 1920x1200 @60Hz, 24bpp
- 1 x HDMI port, supporting a maximum resolution of 4096x2160 @24Hz, 24bpp/ 2560x1600 @60Hz, 24bpp/ 1920x1080 @60Hz, 36bpp
This platform supports dual-display and triple-display function
Multi-GPU Support
• Supports 2-Way AMD CrossFireTM Technology*
*Supports Windows 7 and Windows 8.
BIOS
• The motherboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The motherboard provides a Desktop Management Interface(DMI) function which records your motherboard specifications.
Dimension
• 12.0 in. x 9.6 in. (30.5 cm x 24.4 cm) ATX Form Factor
_________________
ImmagineThe Future is Now !
05/02/2014, 10:48
Profilo WWW
Rispondi citando
Messaggio Re: [Thread Ufficiale] MSI H87-G43
CPU supportate:
Core i7 Haswell i7-4771 100 3.5 1M 8M C0 84 HD Graphics 4600 1200MHz 7816v20.zip
Core i7 Haswell i7-4770T 100 2.5 1M 6M C0 45 HD Graphics 4600 1200MHz 7816v20.zip
Core i7 Haswell i7-4770S 100 3.1 1M 6M C0 65 HD Graphics 4600 1200MHz 7816v20.zip
Core i7 Haswell i7-4770K 100 3.5 1M 8M C0 84 HD Graphics 4600 1250MHz 7816v20.zip
Core i7 Haswell i7-4770 100 3.4 1M 8M C0 84 HD Graphics 4600 1200MHz 7816v20.zip
Core i7 Haswell i7-4765T 100 2.0 1M 8M C0 35 HD Graphics 4600 1200MHz 7816v20.zip
Core i5 Haswell i5-4670T 100 2.3 1M 6M C0 45 HD Graphics 4600 1200MHz 7816v20.zip
Core i5 Haswell i5-4670S 100 3.1 1M 6M C0 65 HD Graphics 4600 1200MHz 7816v20.zip
Core i5 Haswell i5-4670K 100 3.4 1M 6M C0 84 HD Graphics 4600 1200MHz 7816v20.zip
Core i5 Haswell i5-4670 100 3.4 1M 6M C0 84 HD Graphics 4600 1200MHz 7816v20.zip
Core i5 Haswell i5-4570T 100 2.9 512KB 4M C0 35 HD Graphics 4600 1150MHz 7816v20.zip
Core i5 Haswell i5-4570S 100 2.9 1M 6M C0 65 HD Graphics 4600 1150MHz 7816v20.zip
Core i5 Haswell i5-4570 100 3.2 1M 6M C0 84 HD Graphics 4600 1150MHz 7816v20.zip
Core i5 Haswell i5-4440S 100 2.8 1M 6M C0 65 HD Graphics 4600 1100MHz 7816v20.zip
Core i5 Haswell i5-4440 100 3.1 1M 6M C0 84 HD Graphics 4600 1100MHz 7816v20.zip
Core i5 Haswell i5-4430S 100 2.7 1M 6M C0 65 HD Graphics 4600 1100MHz 7816v20.zip
Core i5 Haswell i5-4430 100 3.0 1M 6M C0 84 HD Graphics 4600 1100MHz 7816v20.zip
Core i3 Haswell i3-4340 100 3.6 512KB 4M C0 54 HD Graphics 4600 1150MHz 7816v20.zip
Core i3 Haswell i3-4330T 100 3.0 512KB 4M C0 35 HD Graphics 4600 1150MHz 7816v20.zip
Core i3 Haswell i3-4330 100 3.5 512KB 4M C0 54 HD Graphics 4600 1150MHz 7816v20.zip
Core i3 Haswell i3-4130T 100 2.9 512KB 3M C0 35 HD Graphics 4400 1150MHz 7816v20.zip
Core i3 Haswell i3-4130 100 3.4 512KB 3M C0 54 HD Graphics 4400 1150MHz 7816v20.zip
Pentium Haswell G3430 100 3.3 512KB 3M C0 53 HD Graphics 1100MHz 7816v20.zip
Pentium Haswell G3420T 100 2.7 512KB 3M C0 35 HD Graphics 1100MHz 7816v20.zip
Pentium Haswell G3420 100 3.2 512KB 3M C0 53 HD Graphics 1100MHz 7816v20.zip
Pentium Haswell G3220T 100 2.6 512KB 3M C0 35 HD Graphics 1100MHz 7816v20.zip
Pentium Haswell G3220 100 3.0 512KB 3M C0 53 HD Graphics 1100MHz 7816v20.zip
Celeron Haswell G1830 100 2.8 512KB 2M C0 65 HD Graphics 1050MHz 7816v26.zip
Celeron Haswell G1820T 100 2.4 512KB 2M C0 35 HD Graphics 1050MHz 7816v26.zip
Celeron Haswell G1820 100 2.7 512KB 2M C0 65 HD Graphics 1050MHz 7816v26.zip
Xeon Haswell E3-1285V3 100 3.6 1M 8M C0 84 HD Graphics P4700 1300MHz 7816v20.zip
Xeon Haswell E3-1285Lv3 100 3.1 N/A 8M C0 65 N/A 7816v26.zip
Xeon Haswell E3-1280V3 100 3.6 1M 8M C0 80 N/A 7816v20.zip
Xeon Haswell E3-1275V3 100 3.5 1M 8M C0 84 HD Graphics P4600 1250MHz 7816v20.zip
Xeon Haswell E3-1275Lv3 100 2.9 N/A 4M C0 35 N/A 7816v26.zip
Xeon Haswell E3-1270 v3 100 3.5 N/A 8M C0 80 N/A 7816v26.zip
Xeon Haswell E3-1265LV3 100 2.5 1M 8M C0 45 HD Graphics 1200MHz 7816v20.zip
Xeon Haswell E3-1245V3 100 3.4 1M 8M C0 84 HD Graphics P4600 1200MHz 7816v20.zip
Xeon Haswell E3-1240 v3 100 3.4 N/A 8M C0 80 N/A 7816v26.zip
Xeon Haswell E3-1230V3 100 3.3 1M 8M C0 80 N/A 7816v20.zip
Xeon Haswell E3-1230LV3 100 1.8 1M 8M C0 25 N/A 7816v20.zip
Xeon Haswell E3-1225V3 100 3.2 1M 8M C0 84 HD Graphics P4600 1200MHz 7816v20.zip
Xeon Haswell E3-1220V3 100 3.1 1M 8M C0 80 N/A 7816v20.zip
Xeon Haswell E3-1220LV3 100 1.1 512KB 4M C0 13 N/A 7816v20.zip
_________________
05/02/2014, 10:48
Profilo WWW
Rispondi citando
Recensione sul nostro sito: http://sixupgradeit.com/2014/02/05/sche ... 7-z87-g43/
_________________
05/02/2014, 10:49
Profilo WWW
Rispondi citando
Thread Open
_________________
05/02/2014, 10:49
Profilo WWW
Rispondi citando
Messaggio Re: [Thread Ufficiale] MSI H87-G43 (Intel)
presto una breve recensione sul sito...
_________________
05/02/2014, 11:03
Profilo WWW
Rispondi citando
Personalmente ho mandato in pensione la mia Asrock 4 CoreDualSata 2 e sono passato a questa Scheda Madre, riadattando(esclusa la CPU) tutti i miei "vecchi" componenti:
Scheda audio PCI;
Scheda di rete PCI;
Scheda video PCI (dedicata attualmente alla fisica di nVidia).
Anche la Scheda Video PCI-Ex è stata "riadattata", considerando poi che ora ha a disposizione tutta la banda disponibile su slot PCI-Ex, ricordo che la 4Core aveva un limite imposto di 16x@4x, che comunque ad essere sinceri non si era ancora fatto sentire... per lo meno alle risoluzioni con cui giocavo prima dell'acquisto del nuovo monitor.
_________________
21/02/2014, 22:23
Profilo WWW
Rispondi citando
A breve monterò su questa Scheda Madre la GPU nVidia GTX 960 2G di Galax. Un bel pò di test avranno inizio, rimanete sintonizzati. Emoticons by Follettarosa
Saluti.
_________________
30/03/2015, 14:49
Profilo WWW
Section Moderator Up.It!
Rispondi citando
Saluti.
Curioso di vedere come si comporta la verdona! ;)
_________________
Moderator / Settori di competenza: Scienza
31/03/2015, 21:07
Profilo
cron
Designed by STSoftware.
Hosted by MondoWeb
