Oggi è il 20/06/2019, 19:09
Rispondi all’argomento  [ 6 messaggi ]
 [Thread Ufficiale] Asrock H61M/U3S3 (Intel)
Autore Messaggio
Amministratore Up.It!
Rispondi citando
Messaggio [Thread Ufficiale] Asrock H61M/U3S3 (Intel)
General
CPU - Supports 3rd and 2nd Generation Intel® Core™ i7 / i5 / i3 in LGA1155 Package
- Supports Intel® Turbo Boost 2.0 Technology
- Supports Intel® K-Series unlocked CPU
- Supports Hyper-Threading Technology
Chipset - Intel® H61
- Supports Intel® Rapid Start Technology and Smart Connect Technology
*Intel® Rapid Start Technology and Smart Connect Technology are only supported under Windows® 7 OS or later versions.
Memory - Dual Channel DDR3 memory technology
- 2 x DDR3 DIMM slots
- Supports DDR3 1600/1333/1066 non-ECC, un-buffered memory
- Max. capacity of system memory: 16GB*
- Supports Intel® Extreme Memory Profile (XMP) 1.3 / 1.2 with Intel® Ivy Bridge CPU
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
**DDR3 1600 with Intel® Ivy Bridge CPU, DDR3 1333 with Intel® Sandy Bridge CPU.
BIOS - 32Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- IGPU, DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
Audio, Video and Networking
Graphics - Supports Intel® HD Graphics Built-in Visuals : Intel® Quick Sync Video 2.0, Intel® InTru™ 3D, Intel® Clear Video HD Technology, Intel® Insider™, Intel® HD Graphics 2500/4000 with Intel® Ivy Bridge CPU
- Supports Intel® HD Graphics Built-in Visuals : Intel® Quick Sync Video, Intel® InTru™ 3D, Intel® Clear Video HD Technology, Intel® HD Graphics 2000/3000, Intel® Advanced Vector Extensions (AVX) with Intel® Sandy Bridge CPU
- Pixel Shader 5.0, DirectX 11 with Intel® Ivy Bridge CPU. Pixel Shader 4.1, DirectX 10.1 with Intel® Sandy Bridge CPU.
- Max. shared memory 1760MB with Intel® Ivy Bridge CPU. Max. shared memory 1759MB with Intel® Sandy Bridge CPU.
- Multi VGA Output options: D-Sub, DVI-D and HDMI
- Supports HDMI 1.4a Technology with max. resolution up to 1920x1200 @ 60Hz
- Supports DVI with max. resolution up to 1920x1200 @ 60Hz
- Supports D-Sub with max. resolution up to 2048x1536 @ 75Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI (Compliant HDMI monitor is required)
- Supports HDCP function with DVI and HDMI ports
- Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback with DVI and HDMI ports
*Intel® HD Graphics Built-in Visuals and the VGA outputs can be supported only with processors which are GPU integrated.
**Due to chipset limitation, the Blu-ray playback of Intel® HD Graphics is only supported under Windows® Vista™ and Windows® 7.
***Intel® InTru™ 3D is only supported under Windows® 7 and Windows® 7 x64.
Audio - 5.1 CH HD Audio (Realtek ALC662 Audio Codec)
LAN - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Atheros AR8151
- Supports Wake-On-LAN
- Supports PXE
Expansion / Connectivity
Slots - 1 x PCI Express 3.0 x16 slot (blue @ x16 mode)
- 1 x PCI Express 2.0 x1 slot
- 2 x PCI slots
*PCIe Gen3 is supported on 3rd Generation of Intel® Core™ i5 and Core™ i7 CPUs.
Storage - 2 x SATA3 6.0 Gb/s connectors by ASMedia ASM1061, support NCQ, AHCI and "Hot Plug" functions
USB 3.0 - 2 x USB 3.0 ports by ASMedia ASM1042, support USB 1.0/2.0/3.0 up to 5Gb/s
Connector - 4 x SATA2 3.0 Gb/s connectors, support NCQ, AHCI and Hot Plug functions
- 1 x IR header
- 1 x CIR header
- 1 x Print Port header
- 1 x COM port header
- CPU/Chassis/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O I/O Panel
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x D-Sub Port
- 1 x DVI-D Port
- 1 x HDMI Port
- 4 x Ready-to-Use USB 2.0 Ports
- 2 x Ready-to-Use USB 3.0 Ports
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jack:Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Unique Feature - ASRock Extreme Tuning Utility (AXTU)
- ASRock Instant Boot
- ASRock Instant Flash
- ASRock APP Charger
- ASRock XFast USB
- ASRock XFast LAN
- ASRock XFast RAM
- Hybrid Booster:
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
- Combo Cooler Option (C.C.O.)
- Good Night LED
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version), CyberLink MediaEspresso 6.5 Trial, ASRock MAGIX Multimedia Suite - OEM
Accessories - Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
Hardware Monitor - CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU/Chassis/Power Fan Tachometer
- CPU/Chassis Quiet Fan (Allow Chassis Fan Speed Auto-Adjust by CPU Temperature)
- CPU/Chassis Fan Multi-Speed Control
- Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore
Form Factor - Micro ATX Form Factor: 9.6-in x 8.6-in, 24.4 cm x 21.8 cm
- All Solid Capacitor design (100% Japan-made high-quality Conductive Polymer Capacitors)
OS - Microsoft® Windows® 7 / 7 64-bit / Vista™ / Vista™ 64-bit / XP / XP 64-bit compliant
Certifications - FCC, CE, WHQL
- ErP/EuP Ready (ErP/EuP ready power supply is required)
_________________
ImmagineThe Future is Now !
21/01/2013, 11:38
Profilo WWW
Rispondi citando
Messaggio Re: [Thread Ufficiale] Asrock H61M/U3S3 (Intel)
Edit 2
_________________
21/01/2013, 11:38
Profilo WWW
Rispondi citando
CPU supportate ufficialmente:
1155 Xeon E3-1275V2(E1) Ivy Bridge 3.5GHz BLK 100MHz 8MB 77W P1.70
1155* Xeon E3-1270V2(E1) Ivy Bridge 3.5GHz BLK 100MHz 8MB 69W P1.70
1155 Xeon E3-1265LV2(E1) Ivy Bridge 2.5GHz BLK 100MHz 8MB 45W P1.70
1155 Xeon E3-1245V2(E1) Ivy Bridge 3.4GHz BLK 100MHz 8MB 77W P1.70
1155* Xeon E3-1240V2(E0) Ivy Bridge 3.4GHz BLK 100MHz 8MB 69W P1.70
1155* Xeon E3-1230V2(E0) Ivy Bridge 3.3GHz BLK 100MHz 8MB 69W P1.70
1155 Xeon E3-1225V2(E1) Ivy Bridge 3.2GHz BLK 100MHz 8MB 77W P1.70
1155* Xeon E3-1220V2(E1) Ivy Bridge 3.1GHz BLK 100MHz 8MB 69W P1.70
1155 Core i7 i7-3770K(E1) Ivy Bridge 3.5GHz BLK 100MHz 8MB 77W P1.70
1155 Core i7 i7-3770K(E0) Ivy Bridge 3.5GHz BLK 100MHz 8MB 77W P1.70
1155 Core i7 i7-3770(E1) Ivy Bridge 3.4GHz BLK 100MHz 8MB 77W P1.70
1155 Core i7 i7-3770(E0) Ivy Bridge 3.4GHz BLK 100MHz 8MB 77W P1.70
1155 Core i7 i7-3770T(E1) Ivy Bridge 2.5GHz BLK 100MHz 8MB 45W P1.70
1155 Core i7 i7-3770T(E0) Ivy Bridge 2.5GHz BLK 100MHz 8MB 45W P1.70
1155 Core i7 i7-3770S(E1) Ivy Bridge 3.1GHz BLK 100MHz 8MB 65W P1.70
1155 Core i7 i7-3770S(E0) Ivy Bridge 3.1GHz BLK 100MHz 8MB 65W P1.70
1155 Core i7 i7-2700K(D2) Sandy Bridge 3.5GHz BLK 100MHz 8MB 95W P1.30
1155 Core i7 i7-2600K(D2) Sandy Bridge 3.40GHz BLK 100MHz 8MB 95W All
1155 Core i7 i7-2600(D2) Sandy Bridge 3.40GHz BLK 100MHz 8MB 95W All
1155 Core i7 i7-2600S(D2) Sandy Bridge 2.80GHz BLK 100MHz 8MB 65W All
1155 Core i5 i5-3570K(E1) Ivy Bridge 3.4GHz BLK 100MHz 6MB 77W P1.70
1155 Core i5 i5-3570K(E0) Ivy Bridge 3.4GHz BLK 100MHz 6MB 77W P1.70
1155 Core i5 i5-3570(N0) Ivy Bridge 3.4GHz BLK 100MHz 6MB 77W P1.70
1155 Core i5 i5-3570S(N0) Ivy Bridge 3.1GHz BLK 100MHz 6MB 65W P1.70
1155 Core i5 i5-3570T(E1) Ivy Bridge 2.3GHz BLK 100MHz 6MB 45W P1.70
1155 Core i5 i5-3550(E1) Ivy Bridge 3.3GHz BLK 100MHz 6MB 77W P1.70
1155 Core i5 i5-3550S(E1) Ivy Bridge 3.0GHz BLK 100MHz 6MB 65W P1.70
1155 Core i5 i5-3550S(E0) Ivy Bridge 3.0GHz BLK 100MHz 6MB 65W P1.70
1155 Core i5 i5-3475S(E1) Ivy Bridge 2.9GHz BLK 100MHz 6MB 65W P1.70
1155 Core i5 i5-3475S(E0) Ivy Bridge 2.9GHz BLK 100MHz 6MB 65W P1.70
1155 Core i5 i5-3470(N0) Ivy Bridge 3.2GHz BLK 100MHz 6MB 77W P1.70
1155 Core i5 i5-3470S(N0) Ivy Bridge 2.9GHz BLK 100MHz 6MB 65W P1.70
1155 Core i5 i5-3470T(L1) Ivy Bridge 2.9GHz BLK 100MHz 3MB 35W P1.90
1155 Core i5 i5-3450(E1) Ivy Bridge 3.1GHz BLK 100MHz 6MB 77W P1.70
1155 Core i5 i5-3450S(E1) Ivy Bridge 2.8GHz BLK 100MHz 6MB 65W P1.70
1155* Core i5 i5-3350P(N0) Ivy Bridge 3.1GHz BLK 100MHz 6MB 69W P2.20
1155* Core i5 i5-3350P(E1) Ivy Bridge 3.1GHz BLK 100MHz 6MB 69W P2.20
1155 Core i5 i5-3330(E1) Ivy Bridge 3.0GHz BLK 100MHz 6MB 77W P1.70
1155 Core i5 i5-3330(N0) Ivy Bridge 3.0GHz BLK 100MHz 6MB 77W P2.00
1155 Core i5 i5-3330S(E1) Ivy Bridge 2.7GHz BLK 100MHz 6MB 65W P1.70
1155* Core i5 i5-2550K(D2) Sandy Bridge 3.4GHz BLK 100MHz 6MB 95W P1.30
1155 Core i5 i5-2500K(D2) Sandy Bridge 3.30GHz BLK 100MHz 6MB 95W All
1155 Core i5 i5-2500(D2) Sandy Bridge 3.30GHz BLK 100MHz 6MB 95W All
1155 Core i5 i5-2500S(D2) Sandy Bridge 2.70GHz BLK 100MHz 6MB 65W All
1155 Core i5 i5-2500T(D2) Sandy Bridge 2.30GHz BLK 100MHz 6MB 45W All
1155* Core i5 i5-2450P(D2) Sandy Bridge 3.2GHz BLK 100MHz 6MB 95W P1.30
1155 Core i5 i5-2405S(D2) Sandy Bridge 2.5GHz BLK 100MHz 6MB 65W P1.10
1155 Core i5 i5-2400(D2) Sandy Bridge 3.10GHz BLK 100MHz 6MB 95W All
1155 Core i5 i5-2400S(D2) Sandy Bridge 2.50GHz BLK 100MHz 6MB 65W All
1155 Core i5 i5-2390T(Q0) Sandy Bridge 2.70GHz BLK 100MHz 3MB 35W All
1155* Core i5 i5-2380P(D2) Sandy Bridge 3.1GHz BLK 100MHz 6MB 95W P1.30
1155 Core i5 i5-2320(D2) Sandy Bridge 3.0GHz BLK 100MHz 6MB 95W P1.20
1155 Core i5 i5-2310(D2) Sandy Bridge 2.9GHz BLK 100MHz 6MB 95W All
1155 Core i5 i5-2300(D2) Sandy Bridge 2.80GHz BLK 100MHz 6MB 95W All
1155 Core i3 i3-3240(P0) Ivy Bridge 3.4GHz BLK 100MHz 3MB 55W P2.00
1155 Core i3 i3-3240(L1) Ivy Bridge 3.4GHz BLK 100MHz 3MB 55W P1.90
1155 Core i3 i3-3240T(P0) Ivy Bridge 2.9GHz BLK 100MHz 3MB 35W P2.00
1155 Core i3 i3-3240T(L1) Ivy Bridge 2.9GHz BLK 100MHz 3MB 35W P1.90
1155 Core i3 i3-3225(L1) Ivy Bridge 3.3GHz BLK 100MHz 3MB 55W P1.90
1155 Core i3 i3-3220(N0) Ivy Bridge 3.3GHz BLK 100MHz 3MB 65W P2.00
1155 Core i3 i3-3220(P0) Ivy Bridge 3.3GHz BLK 100MHz 3MB 55W P2.00
1155 Core i3 i3-3220(E1) Ivy Bridge 3.3GHz BLK 100MHz 3MB 55W P2.00
1155 Core i3 i3-3220(L1) Ivy Bridge 3.3GHz BLK 100MHz 3MB 55W P1.90
1155 Core i3 i3-3220T(P0) Ivy Bridge 2.8GHz BLK 100MHz 3MB 35W P2.00
1155 Core i3 i3-3220T(L1) Ivy Bridge 2.8GHz BLK 100MHz 3MB 35W P1.90
1155 Core i3 i3-3210(P0) Ivy Bridge 3.2GHz BLK 100MHz 3MB 55W P2.20
1155 Core i3 i3-2130(Q0) Sandy Bridge 3.4GHz BLK 100MHz 3MB 65W P1.20
1155 Core i3 i3-2125(D2) Sandy Bridge 3.3GHz BLK 100MHz 3MB 65W P1.20
1155 Core i3 i3-2120(Q0) Sandy Bridge 3.30GHz BLK 100MHz 3MB 65W All
1155 Core i3 i3-2120T(Q0) Sandy Bridge 2.6GHz BLK 100MHz 3MB 35W P1.60
1155 Core i3 i3-2105(D2) Sandy Bridge 3.1GHz BLK 100MHz 3MB 65W P1.10
1155 Core i3 i3-2100(Q0) Sandy Bridge 3.10GHz BLK 100MHz 3MB 65W All
1155 Core i3 i3-2100T(Q0) Sandy Bridge 2.50GHz BLK 100MHz 3MB 35W All
1155 Pentium G2120(P0) Ivy Bridge 3.1GHz BLK 100MHz 3MB 55W P1.60
1155 Pentium G2100T(P0) Ivy Bridge 2.6GHz BLK 100MHz 3MB 35W P1.60
1155 Pentium G2020(P0) Ivy Bridge 2.9GHz BLK 100MHz 3MB 55W P2.20
1155 Pentium G2020T(P0) Ivy Bridge 2.5GHz BLK 100MHz 3MB 35W P2.20
1155 Pentium G2010(P0) Ivy Bridge 2.8GHz BLK 100MHz 3MB 55W P2.20
1155 Celeron G1620(P0) Ivy Bridge 2.7GHz BLK 100MHz 2MB 55W P2.20
1155 Celeron G1610(P0) Ivy Bridge 2.6GHz BLK 100MHz 2MB 55W P2.20
1155 Celeron G1610T(P0) Ivy Bridge 2.3GHz BLK 100MHz 2MB 35W P2.20
1155 Pentium G870(Q0) Sandy Bridge 3.1GHz BLK 100MHz 3MB 65W P1.60
1155 Pentium G860(Q0) Sandy Bridge 3.0GHz BLK 100MHz 3MB 65W P1.20
1155 Pentium G860T(Q0) Sandy Bridge 2.6GHz BLK 100MHz 3MB 35W P1.60
1155 Pentium G850(Q0) Sandy Bridge 2.9GHz BLK 100MHz 3MB 65W P1.10
1155 Pentium G840(Q0) Sandy Bridge 2.8GHz BLK 100MHz 3MB 65W P1.10
1155 Pentium G645(Q0) Sandy Bridge 2.9GHz BLK 100MHz 3MB 65W P2.00
1155 Pentium G645T(Q0) Sandy Bridge 2.5GHz BLK 100MHz 3MB 35W P2.00
1155 Pentium G640(Q0) Sandy Bridge 2.8GHz BLK 100MHz 3MB 65W P1.60
1155 Pentium G640T(Q0) Sandy Bridge 2.4GHz BLK 100MHz 3MB 35W P1.60
1155 Pentium G630(Q0) Sandy Bridge 2.7GHz BLK 100MHz 3MB 65W P1.20
1155 Pentium G630T(Q0) Sandy Bridge 2.3GHz BLK 100MHz 3MB 35W P1.20
1155 Pentium G620(Q0) Sandy Bridge 2.6GHz BLK 100MHz 3MB 65W P1.10
1155 Pentium G620T(Q0) Sandy Bridge 2.2GHz BLK 100MHz 3MB 35W P1.10
1155 Celeron G555(Q0) Sandy Bridge 2.7GHz BLK 100MHz 2MB 65W P2.00
1155 Celeron G550(Q0) Sandy Bridge 2.6GHz BLK 100MHz 2MB 65W P1.60
1155 Celeron G540(Q0) Sandy Bridge 2.5GHz BLK 100MHz 2MB 65W P1.10
1155 Celeron G540T(Q0) Sandy Bridge 2.1GHz BLK 100MHz 2MB 35W P1.60
1155 Celeron G530(Q0) Sandy Bridge 2.4GHz BLK 100MHz 2MB 65W P1.10
1155 Celeron G530T(Q0) Sandy Bridge 2.0GHz BLK 100MHz 2MB 35W P1.20
1155 Celeron G465(Q0) Sandy Bridge 1.9GHz BLK 100MHz 1.5MB 35W P2.00
1155 Celeron G460(Q0) Sandy Bridge 1.8GHz BLK 100MHz 1.5MB 35W P1.30
1155 Celeron G440(Q0) Sandy Bridge 1.6GHz BLK 100MHz 1MB 35W P1.10
_________________
21/01/2013, 11:38
Profilo WWW
Rispondi citando
Recensione: http://sixupgradeit.com/2013/01/21/asrock-h61mu3s3/
_________________
21/01/2013, 11:40
Profilo WWW
Rispondi citando
Thread Open
_________________
21/01/2013, 11:40
Profilo WWW
Section Moderator Up.It!
Rispondi citando
Interessante proposta
mi piace il fatto che sia equipaggiata sia di slot pci vecchio stile con il pciex 1x. Chi viene da sistemi più vecchi potrà almeno sfruttare qualche vecchio componente ancora utile tipo scheda di rete, scheda audio ecc.
Se si vuole poi invece aggiungere un hardware discreto moderno possiamo sfruttare lo slot pciex 1x. Ottimo poi il supporto all' usb 3.0.
Manca solo di un connettore ide per eventuali lettori ottici o harddisk vecchio tipo, ma comunque sono disponibili da quello che ho visto nelle altre proposte di schede madri proposte dallo staff. D'altra parte non si può pretendere tutto, i connettori ide sono ormai passato e ad ogni modo questa scheda ha ben 4 connettori sata di cui due sono sata 3.0 per un passaggio dati di ben 6.0Gb/s, che poi se non mi sbaglio è la massima disponibile allo stato attuale, non male direi.
Ho notato che ha già di per se la possibilità di sfruttare l'alta definizione (il full hd) con la vga integrata, poi discreto audio integrato.
In definitiva bella scheda, utile e dai costi contenuti.
Si può poi parlare della capacità massima della memoria che è ottima, 16GB.
Questo è quello che salta maggiormente agli occhi, ma basta dare una letta più attenta alle specifiche tecniche per notare quante altre interessanti funzioni abbia questa mainboard.
ciao
_________________
Moderator / Settori di competenza: Scienza
22/01/2013, 8:27
Profilo
cron
Designed by STSoftware.
Hosted by MondoWeb
