Oggi è il 20/06/2019, 19:14
Rispondi all’argomento  [ 10 messaggi ]
 [Thread Uff.]ASRock 4CoreDualVSTA - (PCIEx/AGP)Support
Autore Messaggio
Amministratore Up.It!
Rispondi citando
Messaggio [Thread Uff.]ASRock 4CoreDualVSTA - (PCIEx/AGP)Support
[color=blue]CPU
- LGA 775 for Intel® Core™ 2 Quad* / Core™ 2 Extreme* / Core™ 2 Duo / Pentium® XE / Pentium® D / Pentium® 4 / Celeron® D, supporting Quad Core Kentsfield processors
- FSB 1066/800/533 MHz
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
*When you adopt Quad Core CPU, FSB may be reduced 5%
Chipset - Northbridge: VIA® PT880 Ultra
- Southbridge: VIA® VT8237A
Memory:
- Dual Channel DDR/DDRII memory technology*
- 2 x DDR2 DIMM slots
- Supports DDRII667/533 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB *(3,3GB in Dual-Channel con Bios Moddati stabili e completi)
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
*DDRII and DDR are supported separately
BIOS - 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports Jumperfree
- SMBIOS 2.3.1 Support
Audio, Video and Networking
Graphics - n/a
Audio:
7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
LAN:
- VIA® PHY VT6103
- Speed: 10/100 Ethernet
- Supports Wake-On-LAN
- Supports PXE
Expansion / Connectivity
Slots:
- 4 x PCI slots
- 1 x PCI Express Graphics slot (@ x4 mode)
- 1 x AGP 8X slot
Connector:
- 2 x SATA 1.5 Gb/s connectors, support RAID (RAID 0, RAID 1, and JBOD) and Hot Plug functions
- 2 x ATA133 IDE connectors (support 4 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- 1 x HDMI_SPDIF header
- CPU/Chassis FAN connector
- 20 pin ATX power connector
- 4 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O HD 8CH I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Serial Port: COM1
- 1 x Parallel Port (ECP/EPP support)
- 4 x Ready-to-Use USB 2.0 Ports
- 1 x RJ-45 LAN Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Unique Feature Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
Accessories - Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 Cables
- 1 x SATA Data Cable (optional)
- 1 x SATA 1 to 1 Power Cable (optional)
- 1 x HDMI_SPDIF Cable (optional)
Hardware Monitor - CPU Temperature Sensing:
- Chassis Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Form Factor
- ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
Sistema Operativo:
- Microsoft® Windows® 2000 / XP / XP 64-bit / Vista™ / Vista™ 64-bit compliant
Certifications:
- FCC, CE, WHQL
_________________
ImmagineThe Future is Now !
13/12/2011, 19:45
Profilo WWW
Senior Member Up.It!
Rispondi citando
Messaggio Re: [Thread Uff.]ASRock 4CoreDual VSTA/SATA-(PCIEx/AGP)Suppo
mi sono iscritto (appena) :D ciao six ... spero che si possano recuperare i precedenti post... ho scritto spesso anche ultimamente, senza essermi accorto del nuovo forum.
_________________
Case:Thermaltake Mozart PSU:Thermaltake Toughpower 750W Board:4coredual-sata2 Heatsink:ZeroTherm Zen120 CPU:X6800 RAM:OCZ Platinum DDR400 GPU:HIS HD3850 AGP PPU:Asus P1 HDD:WD5000AAKS Monitor:Asus VB175T Sound:Creative SBS580 OS:Xp Pro Browser:Srware Iron
15/01/2012, 21:32
Profilo
Section Moderator Up.It!
Rispondi citando
benarrivato
se vuoi recuperare i tuoi precedenti post(ti consiglio di copiare solo quelli che ritieni essere i più importanti) fai copia ed incolla sul thread di interesse ;)
Molti dei thread esistenti sul vecchio forum(quasi tutti) sono stati replicati qui nel nuovo.
buona permanenza nel nuovo forum
ciao
_________________
Moderator / Settori di competenza: Scienza
15/01/2012, 22:03
Profilo
Section Manager Up.It!
Rispondi citando
Benvenuto !
_________________
Section Manager / Sezioni di interesse: Scienza
15/01/2012, 22:34
Profilo
Rispondi citando
Ciao bentrovato ;)
credo che tu abbia sbagliato ubicazione :mrgreen: :
viewtopic.php?f=16&t=9
questo thread è dedicato alla VSATA non alla SATA2
Six
_________________
16/01/2012, 10:03
Profilo WWW
Rispondi citando
EDIT: messaggio in THREAD ERRATO.
_________________
Ultima modifica di Azrael5 il 11/02/2012, 17:46, modificato 1 volta in totale.
11/02/2012, 16:05
Profilo
Rispondi citando
Azrael5 ha scritto:
Sono orgoglioso di annunciare che ho installato la Asus P1 Physx pci express, ed essa funziona perfettamente sulla 4coredual-sata2.
Ti ricordo che questo è il Thread della VSATA...la SATA2 ha un suo Thread dedicato. Come da mio precedente post. ;)
Comunque mi fà piacere per il successo appena ottenuto. Il lavoro e l' impegno prima o poi ripagano. :)
Se ti va puoi descriverci quali erano gli ostacoli e come sei riuscito a oltrepassarli. (Questa volta però sul Thread giusto :mrgreen: )
Ci farebbe piacere. ;)
Six
_________________
11/02/2012, 16:41
Profilo WWW
Rispondi citando
bene ;)
ma che problemi aveva?
ciao
_________________
11/02/2012, 16:53
Profilo
Rispondi citando
six ho capito cosa genera confusione: quello slash con cui separi vsta da sata... dovresti usare il segno "-" ... perchè pare che il thread sia dedicato ad entrambe le schede.
_________________
Ultima modifica di Azrael5 il 12/02/2012, 0:30, modificato 1 volta in totale.
11/02/2012, 17:45
Profilo
Rispondi citando
Messaggio Re: [Thread Uff.]ASRock 4CoreDualVSTA - (PCIEx/AGP)Support
Azrael5 ha scritto:
six ho capito cosa genera confusione: quello slash con cui separi vsta da sata... dovresti usare il segno "-" ... perchè pare che il thread sia dedicata ad entrambe le schede.
Hai ragione, corretto. Ho lasciato solo VSTA.
Six
_________________
11/02/2012, 18:09
Profilo WWW
cron
Designed by STSoftware.
Hosted by MondoWeb
